What is the problem with this print?
quentinthornton
Post by quentinthornton » Fri Oct 21, 2016 7:11 pm
What do I need to change to fix this? (I linked a picture at the bottom)
Re: What is the problem with this print?
Post by Tim » Wed Oct 26, 2016 12:38 am
First we need to know what' s wrong with it. . .
Post by Jules » Wed Oct 26, 2016 1:20 am
Is that ABS or PLA?
Phil
Post by Phil » Thu Oct 27, 2016 3:08 am
It sort of looks like some of my prints when I was using damp nylon. Layers were separated due to vapor replacing plastic at times and otherwise rough.
Post by jsc » Thu Oct 27, 2016 6:42 pm
Have you carried out an extruder calibration? You may be under extruding, which can lead to a rough vertical surface texture. Also, if your nozzle is blowing off steam while printing, then your filament has picked up humidity from the air. Use a fresh batch while you dry it out.
Post by Jules » Thu Oct 27, 2016 6:46 pm
Do come back and tell us a few more details - otherwise it's kind of hard to give you any kind of meaningful answer. Chuckle! :lol:
