Just to clarify a detail based on your last post to make sure you have fully addressed the problem.
For PLA, the nozzle fan needs to run for EVERY layer except the first one, not just layers that take less than 45 seconds. PLA rewards good cooling with very crisp detailing, that is why you see a lot of multiple nozzle fan setups on some printers.
I run 215° C on layer one with no fan (the bed will suck the excess heat out) then 210° C after layer two with the nozzle fan and the bed temp at 50° C.
If you are having layer adhesion issues with the fan on, you may find yourself bumping the heat 5° C or so as needed.
Another detail is that many users have fan ducts installed, which may also affect temps. I have one and the extra cooling power from the duct usually requires a bit higher print temp than you might see on a stock machine to keep the layers sticking to each other well. That may be why you are seeing some 5-10° bumps past the recommended PLA temps.
The nozzle temp is a bit of a flexible number depending on your machine, print settings, and environment. The need for a fan after layer one is not!
