Question using Meshmixer
If I have wall thickness that is less then .40mm, for simplicity, an object like a net or criss crossing walls(logo). How do I change the change the wall thickness globally to a dimension that will print them without having to change the extrusion width.
- willnewton
Re: Question using Meshmixer
I am guessing you did not design whatever it is yourself or you wouldn't ask.
1. Scale it up in two dimensions only. This will thicken without adding height.
2. Draw thicker walls in your CAD software, export them to Meshmixer as an STL and use "Boolean" or "make solid" to unite the STL files.
