Nozzle sizes
Nozzle sizes
I am just getting started in 3D printing, having received my MakerGear M2 last Thursday. I have read quite a lot in different places about clogged nozzles, and while shopping Amazon for some misc. items saw quite a few multi-pack nozzles for a pretty reasonable cost. Most are .4mm nozzles, and when I checked the Wiki for what the M2 comes with, it says:
Prints 1.75mm filament, with a .35mm nozzle (other nozzle sizes are available).
So what does the "other sizes are available" refer to? Is there a range of nozzle sizes I can get that will work with the M2? Does the "typical" .4mm one I find from dozens of sources on Amazon, work with this? They all are specific about saying they are for 1.75mm filament... so assume the nozzle size would refer to the extruded output stream. Is there actually a noticeable difference between extruded .40mm and .35mm in any practical sense that I will care about until I get a whole lot more "expert" at all of this?
thanks!
thanks!
Re: Nozzle sizes
The first thing you need to know is that not all nozzles will fit on the M2. Unless you are sure it will fit, buy your nozzles from MakerGear.
Second thing, if you have S3D, you can adjust pretty easily between nozzle sizes; just remember to change the setting.
Re: Nozzle sizes
Thanks, I found those nozzles on the MakerGear site last night too, they are in my shopping cart
I do use S3D, though still very much a novice with it
Re: Nozzle sizes
Does anybody know a source of compatible nozzles in sizes other than those sold by Makergear? I've read about people using nozzles smaller than 0.25mm and (assuming you keep things clean and don't mind waiting) apparently it can make fine results. The things I'm printing are very small so the added time won't be a big deal compared to the advantages of finer resolution.
Re: Nozzle sizes
Can't help you with different nozzles but you can print some small stuff with a .25 MG nozzle.
Granted this is several different pieces but still pretty good if you ask me.
What are you trying to print that you need really fine detail? There are limits to what FDM printers can do ... depending on what your trying to do an SLA printer might be the way to go.
Re: Nozzle sizes
3DXTech has hardened steel nozzles marketed toward the M2 and M3: https://www.3dxtech.com/makergear-m2-he ... el-nozzle/econopotamus wrote:Does anybody know a source of compatible nozzles in sizes other than those sold by Makergear? I've read about people using nozzles smaller than 0.25mm and (assuming you keep things clean and don't mind waiting) apparently it can make fine results. The things I'm printing are very small so the added time won't be a big deal compared to the advantages of finer resolution.
EDIT: The only have .4mm through .6mm, so might not be what you're looking for...
Re: Nozzle sizes
Yes, those are VERY nice. I actually found your thread with those when I went looking for information on smaller nozzles. I'd love it if you could share your print settings (speeds, temps, etc)sthone wrote:Can't help you with different nozzles but you can print some small stuff with a .25 MG nozzle.
I'm printing microfluidic systems for research. Smaller and cleaner edges is always better, and many of my parts are only 1cm around by 2cm tall, so even with really slow settings the wait isn't bad.
Re: Nozzle sizes
Most of the settings I use are my normal PLA settings (Temps, etc. are set to what ever brand I'm running) but I double check the Extrusion calibration other than that I print a little slower (60mm/s) and I slow my first layer down to 25% and I use a .10 layer height.
Re: Nozzle sizes
My 0.25mm nozzle came in and the first tiny benchy looks good:
https://www.reddit.com/r/3Dprinting/com ... ergear_m2/
I'm going to try even tinier experiments now
