How Do I Get Rid of fine spider threads between parts?
Explorer74
Post by Explorer74 » Sun Nov 12, 2017 5:05 pm
I love my new M3ID, but I get very fine strings as the printer jumps from one area of the print to the next. They are very fine like spider threads. Fairly easy to remove unless they are in a hard to reach spot. Is there a good way to remove them? Like a solution that will dissolve the fine threads without damaging the detail of the print?
Gwhite
Re: How Do I Get Rid of fine spider threads between parts?
Post by Gwhite » Sun Nov 12, 2017 8:17 pm
The folks at Simplify3D have some very good trouble shooting guides. Here's the one you need:
https://www.simplify3d.com/support/prin ... -or-oozing
Explorer74
Post by Explorer74 » Mon Nov 13, 2017 3:22 am
I am already working on prevention, but some prints, like the Klein Bottle vase still get some fuzz. I was wondering if something like fuming would dissolve the fuzz without damaging the print detail.
Gwhite
Post by Gwhite » Mon Nov 13, 2017 3:42 am
There are only a couple dozen different materials you could be printing. A chemical solution will depend rather heavily of what filament you are using. if you are REALLY careful, you may be able to clean them up with a flame:
https://www.youtube.com/watch?v=-zWXFQKt0w4
Hugs
Post by Hugs » Mon Nov 13, 2017 9:17 pm
Explorer74 wrote:Is there a good way to remove them?
Try a hair dryer or heat gun. Works a treat on PETg where stringiness is a problem for some prints.
Post by jimc » Fri Nov 17, 2017 5:24 am
lower your print temp to reduce the fuzz but not so low you have adhesion issues. lower your temp 5 deg at a time until it goes away
