Post
by sthone » Tue Aug 21, 2018 9:25 pm
Yeah apparently they are working with at least 6 manufactures directly (MG included) so this should be exciting... I pulled the trigger on a Pro today.
mathisyourfriend
Post
by mathisyourfriend » Wed Aug 22, 2018 12:02 am
Just watched the printing nerd video and I'm wondering about the mid to long-term problems associated with different materials going through the same hotend/nozzle. Doubts I have:
Printing temps for common materials we use can vary >20%.
Using a soluble (especially PVA with which I had little luck) and other plastics through the same hotend makes me wonder also.
panixx
Post
by panixx » Fri Aug 24, 2018 1:02 am
Seems they recommend using filaments with print temps around 10 degrees of each other.
One thing I noticed in the cameos was the mounting plate on the printer. This doesnt seem like something you could use on an M3-ID as the stepper motor for the second motor would be in the way. It would need to stick out a bit in order to be able to be mounted.
mathisyourfriend
Post
by mathisyourfriend » Fri Aug 24, 2018 3:12 pm
Thanks. I was thinking they were mixing flexible/higher temp filaments with PLA/ABS in the same prints.
