M2 max operating temperature
Posted: Tue Aug 26, 2014 10:06 pm
I'm building an enclosure for my M2. What is the maximum operating temperature of the control electronics on the M2?
I was just browsing the MakerGear components page; they mention the position of the adjustment screws:jsc wrote: Bed Leveling and Z-height Adjustment Methods
From Toby:
This method assumes that your bed and z-height have been leveled once but might be in need of minor adjustment from print to print. It also assumes that you are using Simplify3D, though it is likely to be adaptable to other printer-control software.
It may be desirable to pre-heat the bed to your printing temperature before starting.
In Simplify3D open the Bed Leveling Wizard (under Tools on the main screen) and set the "Z height for leveling moves" to 0.0. (In versions earlier than 2.1, it will be necessary to also keep the Machine Control Panel open and accessible on the screen. Depending on your computer and operating system this may involve resizing and repositioning these windows. Put the Machine Control panel in jog mode.)
Click the "Manually enter leveling positions" radio button and put the following locations in the manual portion of the dialog:
100 175
100 75
150 125
50 125
Once entered, they will not need to be entered again. The first three coordinates are the locations of the adjustment screws in the spider. (Note: It would be nice to verify this or find the exact values.)
When the glass bed is mounted, the three spider mount screws are at (102.1,77.5), (102.1,177.5) and (152.1,127.5) with the front left corner of the glass at (0,0).
