some handy tools for cleaning the hot end
Re: some handy tools for cleaning the hot end
Thank Jim, ordered these they should arrive tomorrow.
I broke it in under 30 seconds.Artenen wrote:broke that little bit in under 1 minute...
haha GENTLE guys lol. its not like a piece of wire. it is a carbide bit so its rock hard and brittle. any sideways force and you'll snap it. its so fine and has no flex at all very lightly spin between your fingers.
I don't have the finesse for tiny drill bits. I break them.
I always try to clear my clocks by overheating the hot end and hand-forcing the filament through. And the one time that didn't work, I dismantled and took a propane torch to the nozzle. Which worked perfectly.
I read somewhere about using a guitar string as a nozzle probe. Does anyone recall what the correct string is?
Gary
Make Better Things
Make Things Better
Make Better Things
Make Things Better
It depends entirely on what gauge strings you have wired up on your guitar. They sell different tensions of strings.Lateralg wrote:I read somewhere about using a guitar string as a nozzle probe. Does anyone recall what the correct string is?
the 0.35 mm nozzle is 0.0138 inches. And guitar strings are rated in thousands of inches, so you're looking for a 13.
So if you've got a set of Ernie Ball Regular Slinky, you'd use your B string.
Earnie Ball 2221 - Regular Slinky 10, 13, 17, 26, 36, 46
Generally, the 4 bigger strings are wound, so steer clear of those.
guitar strings work great. i use them for cleaning my airbrushes and spray guns. they will work equally as well for the nozzle. i dont know the size though. walk into your local music shop with a pair of calipers and see what they say lol.
Good plan. I will execute soonest.jimc wrote:guitar strings work great. i use them for cleaning my airbrushes and spray guns. they will work equally as well for the nozzle. i dont know the size though. walk into your local music shop with a pair of calipers and see what they say lol.
I like guitar string over drill bit. I had a perfect drill bit that broke off inside nozzle during cleaning adding to my woes.
Gary
Make Better Things
Make Things Better
Make Better Things
Make Things Better
Tinkered with some strings I had laying around. The .013 I had (B string in my case) did fit through the .35mm nozzle, but not easily.
The .011 I had (E string) fit through easily and seemed to do the job pretty well. I just had to cut it on an angle with my cutters.
And I've got a .014 (Bronze Acoustic B string) that does not fit through the opening at all.
So I think that answers the question.
It certainly does. Thank you.Levi8than wrote:Tinkered with some strings I had laying around. The .013 I had (B string in my case) did fit through the .35mm nozzle, but not easily.
Gary
Make Better Things
Make Things Better
Make Better Things
Make Things Better
