XTC-3D test
XTC-3D test
I finally got around to testing out my XTC-3D printing epoxy from Smooth-On. The vase is a single thickness twisted vase in esun PETG, coated inside and outside. It visibly increases the translucency. The black thing is a PLA safety razor top cap with a single layer coating. I did a very hasty job, so the coating on the vase isn't perfectly even and I did end up with one blob, but the self-leveling is pretty good after you let it sit until it sets.
- xtc-3d.jpeg (182.1 KiB) Viewed 10316 times
Re: XTC-3D test
Holy coprolite Batman! Those are spectacular jin! The vase looks like Venetian glass! Is that sprayed on?
Re: XTC-3D test
No, it is a two-part epoxy that is kind of thin. You brush it on with a disposable foam brush. Pot life 10-15 minutes, non-tack setting in 2 hours.
Here's the razor after it's been sanded. There is visible grain, but the surface is glassy smooth to the touch.
- razor-xtc-3d.jpg (115.53 KiB) Viewed 10298 times
Re: XTC-3D test
Jeez! That looks like brushed steel. Does it have an odor?
Re: XTC-3D test
Gonna have to try that one day when I grow up as a 3D-er then. That is incredible - especially on that vase!
