settings for PLA printing part at .050mm
wisdomknight
Post by wisdomknight » Tue Apr 19, 2016 7:26 pm
Right now Im using the black PLA that came packed with the M2.
Temperatures 220 extruder and 70 bed (hairspray)
Im trying to print a part at .050mm.
What is the recommended settings for something at this resolution?
It starts off good then either starts pullin off bed after a couple minuted or becomes a mess.
I have a .35mm nozzle and I can print successfully at .100mm or higher but thats it
Any help would be appreciated.
wisdomknight
Re: settings for PLA printing part at .050mm
Post by wisdomknight » Tue Apr 19, 2016 7:34 pm
ok went up to .100mm and still popping off bed after a few minutes
wisdomknight
Post by wisdomknight » Tue Apr 19, 2016 7:36 pm
would the tape be better at these resolutions?
wisdomknight
Post by wisdomknight » Tue Apr 19, 2016 8:18 pm
reduced temps to 190 and 45, same thing starts off with perfect layeres.
Then after a couple min starts popping off everywhere, way worse at these lower temps!
Post by insta » Tue Apr 19, 2016 8:31 pm
Popping off the bed (at 60C) means you're too high off the bed. Adjust accordingly.
wisdomknight
Post by wisdomknight » Tue Apr 19, 2016 8:36 pm
now tried 220 and a 75 bed.
way better hotter but still starts coming off .
done for the day.
wisdomknight
Post by wisdomknight » Tue Apr 19, 2016 8:37 pm
insta wrote:Popping off the bed (at 60C) means you're too high off the bed. Adjust accordingly.
the nozzle?
Post by insta » Tue Apr 19, 2016 10:01 pm
the nozzle?
Yep. Set your first layer height to 400% or so.
wisdomknight
Post by wisdomknight » Tue Apr 19, 2016 10:22 pm
thank you I will try!
wisdomknight
Post by wisdomknight » Wed Apr 20, 2016 7:25 pm
insta wrote:
the nozzle?
Working great now!
Thank you soo much!
