connecting PLA model parts -tip
sonra
Post by sonra » Wed May 04, 2016 12:33 pm
Hi guys
I use only PLA and the difficult problem I found is hoe to connect parts after print . I try 2 second Loctite super glue and gel . The gel work but it took long time to get dry , Someone in Israel told me about the idea described in article ( link is attached ) ,I tried the friction W welding and this is great , it take sometime to prepare the parts but it make me life in this point much easier .
http://makezine.com/projects/make-34/sk ... d-objects/
thunderbt3
Re: connecting PLA model parts -tip
Post by thunderbt3 » Wed May 04, 2016 1:17 pm
You could try CA glue kicker. You glue up your parts and then spritz it over the joint and it should set the glue immediately.
http://www.amazon.com/Bob-Smith-151-Ins ... B0000DD1QR
Epoxy also works and comes in different working times such as 5 minutes or 30 minutes.
Matt_Sharkey
Post by Matt_Sharkey » Wed May 04, 2016 5:07 pm
I use Weld On #4
It's just Methyl Chloride, which isnt a glue, but it chemically welds the parts together. Much like acetone welding with ABS.
