How to print objects that don't have a flat side?
RJD
Post by RJD » Sun May 15, 2016 1:48 pm
I have been steadily figuring out the printing process over the last few months. How do you print objects, such as in the following links, that don't have a flat side to place on the printer bed of the software? I am utilizing Simplfy3D. Thanks.
http://www.thingiverse.com/thing:686357
http://www.thingiverse.com/thing:895257
zemlin
Re: How to print objects that don't have a flat side?
Post by zemlin » Sun May 15, 2016 2:39 pm
For the lure body, I'd print that on a raft with support. If you don't want the rougher underside, split it in half and print it in two pieces that get glued together.
For some parts similar to the rod, I've printed them on end rather than laying down. The rod you link to is pretty long and skinny, so not a great candidate for that. I have used a brim attached at the bottom to give a part a larger foot print to improve stability. I also slow the speed way down on a tall part (all speeds, not just the print speed) so the part isn't jerked around on the table so much - help it stay standing tall.
Post by jimc » Sun May 15, 2016 10:41 pm
zemlin pretty much nailed it and gave really good advise. the best thing you can do when printing parts like this is to split it down the middle, print 2 halves and glue or solvent bond the 2 pieces together. i manage to do 95% of all my prints without using any support at all by modeling things in pieces then assembling or solvent bonding together.
RJD
Post by RJD » Sun May 15, 2016 11:56 pm
Thanks for the help. Can Simplify 3D split an object in half/multiple parts or is another piece of software required to accomplish this?
Post by jimc » Mon May 16, 2016 12:11 am
You can do this in simplify in most cases. Simplify wont print anything below the bed so double click the model and lower the model in the z axis, print then flip it OR duplicate it and flip one then print both halves at the same time
Post by Jules » Mon May 16, 2016 12:18 am
jimc wrote:You can do this in simplify in most cases. Simplify wont print anything below the bed so double click the model and lower the model in the z axis, print then flip it OR duplicate it and flip one then print both halves at the same time
There's a write-up for what Jim is discussing here:
viewtopic.php?f=3&t=3431
RJD
Post by RJD » Mon May 16, 2016 1:05 am
Thank you.
