remove Elmer's Extra Strength Glue Stick from Kapton
jferguson
Post by jferguson » Fri Aug 18, 2017 9:11 pm
It takes Acetone and a whole lot of rubbing. This stuff may be overkill, at least with PLA - sort of why use a knife when there's an ax around.
Re: remove Elmer's Extra Strength Glue Stick from Kapton
Post by insta » Fri Aug 18, 2017 10:07 pm
Hot water and a scrubby didn't do it?
jferguson
Post by jferguson » Fri Aug 18, 2017 10:32 pm
insta wrote:Hot water and a scrubby didn't do it?
Nuts. I never would have thought of it. At least I didn't try MEK.
3dPrintingMD
Post by 3dPrintingMD » Mon Aug 21, 2017 2:12 pm
Glue stick just needs water. Take the plate off, turn on the faucet and let water run over it. Try cold or hot, see what works best. I use that and a sponge to remove.
jferguson
Post by jferguson » Mon Aug 21, 2017 2:53 pm
Amazingly, possibly stupidly, I decided to just leave it on. I now have some "tooth" for the PLA to stick to. The shear strength of the glue-PLA bond is pretty amazing. the PLA-kapton bond is pretty good too.
jferguson
Post by jferguson » Tue Aug 22, 2017 4:24 pm
Were you guys ever right about the warm water and scrubby. :D :D
