supports for PETG
supports for PETG
Postby psd » Wed Sep 06, 2017 3:15 pm
Does anyone have better settings for supports for PETG,
my supports are either too close and bond too well with my models, or too far, what settings should I play with for best results?
- peter,
Re: supports for PETG
Postby Gwhite » Wed Sep 06, 2017 10:14 pm
I've only used supports once, but the settings in Jules's wonderful thread on eSun PETG worked fine for me with HatchBox black:
6. Support:
Generate Support Material: checked if needed
Support infill percentage: 30%
No Dense Support
Horizontal Offset: 0.3 mm
Upper Vertical Separation Layers: 1
Lower Vertical Separation Layers: 0
The supports broke out fairy cleanly, and the residual material cleaned up just fine. I had ~ 10 mm diameter holes in an 8 mm thick vertical wall, and I could clean them up with a reamer.
Return to How-to/Guides/Tips
Who is online
Users browsing this forum: No registered users and 1 guest
