I made whoDats LCD enclosure
jdacal
Post by jdacal » Mon Jul 14, 2014 6:57 am
This is my second project with the new M2. Only really bad thing I see is the two rear corners curled up a bit, otherwise fully functional. I also made an HD video that you can see on Vimeo:
https://vimeo.com/user23683089/review/1 ... a58bb4f69b
2014-07-13 15.30.38_1.jpg (169.47 KiB) Viewed 16535 times
2014-07-13 15.29.58_1.jpg (167.43 KiB) Viewed 16535 times
2014-07-13 15.29.45_1.jpg (177.77 KiB) Viewed 16535 times
jdacal
Dale Reed
Re: I made whoDats LCD enclosure
Post by Dale Reed » Tue Jul 15, 2014 2:16 am
I think all this needs for near-perfection is jimc's clamp to firmly hold the 6=pin power input connector in place. Nice print!
Post by jimc » Tue Jul 15, 2014 2:21 am
yes its a nice enclosure for sure. if i remember right someone recently modified my enclosure to hold the viki as well. i think its on thingiverse.
jdacal
Post by jdacal » Tue Jul 15, 2014 6:34 am
Dale Reed wrote:I think all this needs for near-perfection is jimc's clamp to firmly hold the 6=pin power input connector in place. Nice print!
Thanks Dale, I'll check that out, hadn't found that one yet.
jdacal
jdacal
Post by jdacal » Tue Jul 15, 2014 6:44 am
jimc wrote:yes its a nice enclosure for sure. if i remember right someone recently modified my enclosure to hold the viki as well. i think its on thingiverse.
I had seen your enclosure jimc but I somehow missed that there was a Viki version. Looks nice, I like the way its offset to the right.
jdacal
markb
Post by markb » Wed Jul 16, 2014 3:43 am
I like very nice…
Levi8than
Post by Levi8than » Wed Jul 23, 2014 6:19 pm
I need to make this. My LCD walks off the table with the vibration.
What is Jimc's clamp? do you have a link?
Post by jimc » Thu Jul 24, 2014 12:10 am
yes here is a link to my box. no viki but if you click on the "made" link there is a guy there who modified my box to fit a viki. the clamp/lock is just a piece that goes on the back side which holds in the power connectors on the rambo keeping them from coming loose and having a melt down.
http://www.thingiverse.com/thing:157239
jdacal
Post by jdacal » Sat Aug 16, 2014 9:20 pm
I originally did the print in PLA. Shortly after the cover warped on it. Either due to heat from the board or possibly the wiring harnesses inside applying some upward pressure to the PLA cover.
I re-printed the cover with ABS and seems to be holding up fine now.
jdacal
