ABS Mold
jdacal
Re: ABS Mold
Post by jdacal » Wed Oct 29, 2014 6:06 am
Ok, here's the "Team MakerGear" version. I went ahead and ordered a .50 nozzle, nobody seemed to have the .40 in stock. Anyway came out much heftier now after following the suggestions, thanks for the help! :
2014-10-29 00.56.50_1.jpg (180.23 KiB) Viewed 7050 times
2014-10-29 00.57.06_1.jpg (149.07 KiB) Viewed 7050 times
jdacal
Re: ABS Mold
Post by insta » Wed Oct 29, 2014 2:51 pm
Just for S&G, can you put the 0.35mm nozzle back on, and slice that part with the new version of Slic3r? It has a feature, some kind of adaptive infill, that will pump up the extrusion width for cases like you had. I'm curious if it'll work here.
Re: ABS Mold
Post by jsc » Wed Oct 29, 2014 5:12 pm
Here's what it looks like sliced with Slic3r.
jdacal
Re: ABS Mold
Post by jdacal » Wed Oct 29, 2014 5:17 pm
insta wrote:Just for S&G, can you put the 0.35mm nozzle back on, and slice that part with the new version of Slic3r? It has a feature, some kind of adaptive infill, that will pump up the extrusion width for cases like you had. I'm curious if it'll work here.
Hi insta, I haven't receive the .50 nozzle yet. I did that with S3D by adjusting the extrusion width. I've never used Slicer yet, but may try it later tonight and let you know how it turns out.
jdacal
