zucco
Post
by zucco » Mon Jan 12, 2015 12:37 am
- zucco-what.jpg (81.17 KiB) Viewed 3885 times
- I have been trying to print out this model for a few months with PLA, but there was always a problem.
Switching to ABS resulted in a successful print. The model is 6 x 2.5 inches. - (563.6 KiB) Downloaded 366 times
- top and bottom view
- zucco-lion-tb.jpg (394.72 KiB) Viewed 3906 times
- This is the orientation I printed the lion.
In this position the teeth printed well. - zucco-lion2.jpg (63.4 KiB) Viewed 3923 times
- The PLA was melting and warping during the print.
The extruder head knocked the model off the base and it was printing in thin air. - lion-blooper.jpg (24.28 KiB) Viewed 3923 times
zucco on Mon Jan 12, 2015 3:55 am, edited 7 times in total.
Post
by jsc » Mon Jan 12, 2015 2:12 am
PLA is generally considered to be easier to print with, but one major problem with it is that it curls on overhangs without sufficient cooling. You see this very often with sculptural models. The edges will curl up and eventually cause a print failure if it gets too severe. An extra fan often helps in those cases.
