A Heat Chamber for the M2
Re: A Heat Chamber for the M2
I hear ya on the cost of the pet+. The difference isnt quite so bad when you factor in all the failed and warped abs prints but its still a little pricy even with that. I sorta moved away from it since all the other brands are either a little to way cheaper. Most decent good grade plastics these days have uv inhibitors in them BUT its almost never advertised so unless you ask the manufacturer specifically then there is no way of knowing for sure. I am guessing that your going to be ok with the madesolid stuff but a quick email will tell all. I believe i read somewhere the esun petg had uv inhibitors in it but im not 100% on that.
