Here's the gcode from S3D with all my settings. Make sure the bed is super level, I use a dial indicator and make sure your hot end height is tweaked to perfection. I started with this profile. M2_PLA_0.20_High_Quality and tweaked it a little to my preference.
http://www.thingiverse.com/thing:269637/#files
G-Code generated by Simplify3D(R) Version 2.2.2
; Feb 16, 2015 at 2:57:53 PM
; Settings Summary
; processName,M2 PLA 0.20 High Quality
; applyToModels,stem_130421a,rose_4_130420c
; profileLabel,dwk_makergear_m2.fff
; printMaterial,PLA
; printQuality,Medium
; extruderName,Primary Extruder
; extruderToolheadNumber,0
; extruderDiameter,0.35
; extruderAutoWidth,1
; extruderWidth,0.42
; extrusionMultiplier,1
; extruderUseRetract,1
; extruderRetractionDistance,1.4
; extruderExtraRestartDistance,0
; extruderRetractionZLift,0.25
; extruderRetractionSpeed,3000
; extruderUseCoasting,1
; extruderCoastingDistance,1.4
; extruderUseWipe,1
; extruderWipeDistance,5
; primaryExtruder,0
; layerHeight,0.2
; topSolidLayers,4
; bottomSolidLayers,4
; perimeterOutlines,1
; printPerimetersInsideOut,1
; startPointOption,2
; startPointOriginX,0
; startPointOriginY,0
; startPointOriginZ,300
; sequentialIslands,1
; spiralVaseMode,0
; firstLayerHeightPercentage,90
; firstLayerWidthPercentage,100
; firstLayerUnderspeed,0.6
; useRaft,0
; raftExtruder,0
; raftLayers,4
; raftOffset,9
; raftSeparationDistance,0.14
; raftInfill,85
; disableRaftBaseLayers,0
; useSkirt,1
; skirtExtruder,0
; skirtLayers,2
; skirtOutlines,2
; skirtOffset,8
; infillExtruder,0
; externalInfillPattern,Rectilinear
; infillPercentage,20
; outlineOverlapPercentage,10
; infillExtrusionWidthPercentage,100
; minInfillLength,5
; infillLayerInterval,1
; randomInfillStartPoint,0
; infillAngles,45,-45
; generateSupport,0
; supportExtruder,0
; supportInfill,40
; supportExtraInflation,0
; denseSupportLayers,0
; denseSupportInfill,75
; supportLayerInterval,1
; supportHorizontalPartOffset,0.5
; supportUpperSeparationLayers,1
; supportLowerSeparationLayers,1
; supportGridSpacing,4
; maxOverhangAngle,45
; supportAngles,0
; temperatureName,Primary Extruder,Heated Bed
; temperatureNumber,0,2
; temperatureSetpointCount,2,1
; temperatureSetpointLayers,1,2,1
; temperatureSetpointTemperatures,215,215,65
; temperatureStabilizeAtStartup,1,0
; temperatureHeatedBed,0,1
; temperatureRelayBetweenLayers,0,0
; temperatureRelayBetweenLoops,0,0
; fanLayers,1,2
; fanSpeeds,0,100
; blipFanToFullPower,1
; adjustSpeedForCooling,1
; minSpeedLayerTime,30
; minCoolingSpeedSlowdown,25
; increaseFanForCooling,0
; minFanLayerTime,45
; maxCoolingFanSpeed,100
; increaseFanForBridging,0
; bridgingFanSpeed,100
; use5D,1
; relativeEdistances,0
; allowEaxisZeroing,1
; independentExtruderAxes,0
; includeM10123,0
; stickySupport,1
; detectArcs,0
; arcReplaceG2G3,0
; arcRadialCompensation,1
; gcodeXoffset,0
; gcodeYoffset,0
; gcodeZoffset,-0.08
; overrideMachineDefinition,1
; machineTypeOverride,0
; strokeXoverride,200
; strokeYoverride,250
; strokeZoverride,200
; originOffsetXoverride,0
; originOffsetYoverride,0
; originOffsetZoverride,0
; homeXdirOverride,-1
; homeYdirOverride,-1
; homeZdirOverride,-1
; flipXoverride,1
; flipYoverride,-1
; flipZoverride,1
; startingGcode,M204 T10000 ; increase default retraction acceleration,M201 X1200 Y800 Z500 ; reduce maximum acceleration to reduce ringing,G28 ; home all axes,G1 Y50 Z0.3 F9600 ; move forward to avoid binder clips,G1 X205 Z10 ; move off platform,G1 Z0.4 ; position nozzle,G92 E0 ; zero extruder,G1 E25 F225 ; purge nozzle,G92 E0 ; zero extruder,G1 X190 Z0.1 E1.0 F1200 ; slow wipe,G1 X180 Z0.25 ; lift
; layerChangeGcode,
; toolChangeGcode,
; endingGcode,M104 S0 ; turn off extruder,M140 S0 ; turn off bed,G91 ; relative mode,G1 E-1 F300 ;retract the filament a bit before lifting the nozzle to release some of the pressure,G1 Z+0.5 E-5 X-20 Y-20 ;move Z up a bit and retract filament even more,G1 Z10 ; lift 10mm,G90 ; absolute mode,G28 X0 ; home X axis,M107,G1 Z195 F2500,M84 ; disable motors
; createX3G,0
; celebration,0
; celebrationSong,Random Song
; createMB5G,0
; postProcessing,
; defaultSpeed,4800
; outlineUnderspeed,0.6
; solidInfillUnderspeed,0.8
; supportUnderspeed,0.8
; rapidXYspeed,9600
; rapidZspeed,1200
; minBridgingArea,10
; bridgingExtrusionMultiplier,0.6
; bridgingSpeedMultiplier,1
; filamentDiameter,1.75
; filamentPricePerKg,25
; useMinPrintHeight,0
; minPrintHeight,0
; useMaxPrintHeight,0
; maxPrintHeight,0
; useDiaphragm,0
; diaphragmLayerInterval,20
; robustSlicing,1
; mergeAllIntoSolid,0
; onlyRetractWhenCrossingOutline,0
; retractBetweenLayers,0
; useRetractionMinTravel,1
; retractionMinTravel,3
; useRetractionOozeRate,0
; retractionOozeRate,100
; onlyWipeOutlines,1
; toolChangeRetractionDistance,0
; toolChangeExtraRestartDistance,0
; toolChangeRetractionSpeed,360
; allowThinWallGapFill,1
; thinWallAllowedOverlapPercentage,10
; horizontalSizeCompensation,0
; G-Code generated by Simplify3D(R) Version 2.2.2
; Settings Summary
; printMaterial,PLA
; extruderUseWipe,1
; primaryExtruder,0
; layerHeight,0.2
; topSolidLayers,4
; spiralVaseMode,0
; useRaft,0
; raftExtruder,0
; raftLayers,4
; raftOffset,9
; raftInfill,85
; useSkirt,1
; skirtExtruder,0
; skirtLayers,2
; skirtOutlines,2
; skirtOffset,8
; infillExtruder,0
; minInfillLength,5
; generateSupport,0
; supportExtruder,0
; supportInfill,40
; supportAngles,0
; fanLayers,1,2
; fanSpeeds,0,100
; use5D,1
; includeM10123,0
; stickySupport,1
; detectArcs,0
; arcReplaceG2G3,0
; gcodeXoffset,0
; gcodeYoffset,0
; flipXoverride,1
; flipYoverride,-1
; flipZoverride,1
; layerChangeGcode,
; toolChangeGcode,
; createX3G,0
; celebration,0
; createMB5G,0
; postProcessing,
; defaultSpeed,4800
; rapidXYspeed,9600
; rapidZspeed,1200
; minPrintHeight,0
; maxPrintHeight,0
; useDiaphragm,0
; robustSlicing,1
Rose
Re: Rose
thank youdklassen wrote:Here's the gcode from S3D with all my settings. Make sure the bed is super level, I use a dial indicator and make sure your hot end height is tweaked to perfection. I started with this profile. M2_PLA_0.20_High_Quality and tweaked it a little to my preference.
Re: Rose
Wow! That came out great.
