Code: Select all
G91 ; set relative positioning
G0 Z20 ; raise Z (drop bed)
G1 E-10 ; retract
G90 ; set absolute positioning
M84 S0 ; disable idle timeout
M0 ; pause
Code: Select all
G1 E-10 ; retract
M0 ; pause
Code: Select all
M0 ; pause
Marlin doesn't implement M0 in the V1.0.0 code used in Makergear's versions, so it's effectively a no-op.sthone wrote:but it never paused
Code: Select all
// M0 - Unconditional stop - Wait for user to press a button on the LCD (Only if ULTRA_LCD is enabled)
// M1 - Same as M0
Code: Select all
M25: Pause SD print
