Scanned stuffed bear
Scanned with a Structure Scanner and iPhone 6. Repaired with Skanect. Sliced and scaled with S3D.
- (168.14 KiB) Downloaded 346 times
Re: Scanned stuffed bear
Cute! The Teddy's got a Teddy!
Scanned with a Structure Scanner that connected to a iPhone using a app called itSeez3D. You walk around the subject and it captures the object with laser and IR to build a model. It was cleaned up in Skanect. I also did people scans and printed some bust to use as Monopoly pieces I gave them to the models. I may have pics available tomorrow. Can use a iPad but i had the wrong adapter.
Here's a hands on review of that scanner: http://www.tested.com/tech/3d-printing/ ... d-scanner/
Looks interesting, if I needed a scanner.
