Page 1 of 2
Big Red Beast. A 3D printed quadrotor
Posted: Sun May 18, 2014 6:19 am
by JohnnyRobot
Hey everybody,
Just wanted to share with you my latest creation. A 550 series quadrotor.
This picture is of only the frame and battery. I will post more as things progress.
Re: Big Red Beast. A 3D printed quadrotor
Posted: Mon May 19, 2014 3:36 pm
by JohnnyRobot
Any ideas on what I should name this thing?
A different lander gear config. A little bit further along..
Posted: Tue May 20, 2014 1:32 pm
by JohnnyRobot
Posted: Tue May 20, 2014 5:51 pm
What are you using to model? Are those carbon fiber rods for the arms? What are you going to do for cable management to the rotors? Where does the battery go?
Posted: Tue May 20, 2014 6:15 pm
by JohnnyRobot
I'm using Alibre Design.
And yes, the arms are .5" carbon fiber tubes. The motor wires are to be routed through them. Unfortunately .5" is a bit too small and they're very difficult to fit in there. I may need to find smaller connectors. (Or just solder them
The top picture is of an initial fitment test. There's an additional plate holding the battery that's not installed on the bottom picture.
The bottom picture was right after I calibrated the ESC, I assembled it so the motors would be secured while I was calibrating and testing motor direction. (I put propellers on for the photo)
I'll post another one tonight after I add more goodies.
Update - 5/21/14
Posted: Wed May 21, 2014 1:25 pm
by JohnnyRobot
Build log update.
I didn't get to work on it much yesterday. Not enough time in a day...
Here's what I did get done.
- Calibrated ESC
- Verified motor rotation
- Replaced motor connectors with wire to wire solder. (not happy about it, but the wires fit through the arm tubes now)
Posted: Thu May 22, 2014 1:38 am
by j-rod
you could always space the connectors at different lengths along the wire so they aren't all bunched up at one spot, but that's a tad bit more work.
Posted: Thu May 22, 2014 3:50 pm
by JohnnyRobot
I thought of that
after I cut my motor wires too short.
Update - 5/22/14
Posted: Thu May 22, 2014 4:11 pm
by JohnnyRobot
It Flies! AND Crashes...
Posted: Mon May 26, 2014 6:22 am
by JohnnyRobot
Pay close attention @ 2:17
http://youtu.be/jqyysKg7WJw
