wmgeorge wrote:BTW you Can run a gasoline engine off Browns gas, but the economics are not there. Yes your running a car on water... sort of.
Well, the energy to convert the water to hydrogen has to come from somewhere, and that is coming from burning gas if you're getting electricity from the alternator. At best, people injecting browns gas into their engine are increasing the efficiency of the engine by burning more of the fuel. They are not, as many claim, running the car on water. It is technically possible to run the car on just Browns Gas if you had a source of it, but since it can not be compressed without exploding, there is no way to store it. Thus it has to be made on demand, which means some other energy source is required to make it.
If it takes X number of watts to create X liters of H then it makes no difference if your on 12 volts or 220 volts.... its the watts that count.
True, but for a given number of watts current increases as voltage decreases and high current is the limiting factor on your wiring. Even running 30 amps through a typical 12 gauge wire is going to heat it up. Higher voltage lets you get more gas production from the same amount of current in these hydrogen generators. The 12v cell shown here is pulling around 12 to 15 amps (current increases as it heats up). Ten of these operating in parallel would draw a prohibitive 150 amps, whereas I can build a 120v unit that uses 10 times as many internal plates and get 10 times the gas production for the same 12 to 15 amp current draw. Lower voltages like 12v also require power supplies to drop the voltage down and regulate it, and power supplies get a lot more expensive as the current rating goes up due to all the internal components having to be rated for high current. Because voltage regulation and other fancy power management features are not needed for something like this, you can just run 120VAC through a full bridge rectifier and run the humpback DC that comes out of that right to the cell, eliminating the costly power supply from the picture.
