I recently had to disassemble my V3b hotend to clean a stubborn clog. Now that everything is cleaned, the heater element and the thermistor are too loose in the heater block. They insert very easily, but I think that the motion of the hotend would be enough to dislodge them. I have a spare V3b hotend and the heater and thermistor are stay put when gentle pressure is applied. To my mind, it also appears that the tiny airgap between the heater and the block would create an inefficient heat transfer, and the air gap between block and thermistor would create inaccurate temperature readings.
How snug should these parts be? Would a thermal paste such as heatsink grease (e.g. Artic Silver http://www.amazon.com/Arctic-Silver-The ... B000OGX5AM) work? I think the grease might bridge the air gap enough to prevent the parts sliding out and create more efficient heat transfer. Has anyone encountered this before?
Heater Block fit
Re: Heater Block fit
There's a set screw that holds the heater cartridge, and the zip-tie against the thermistor legs holds it in place. What happened with the set screw on yours?
shadowwynd
Forgot about the set screw.
