Dual Extruder Upgrade
sckibbons
Post by sckibbons » Fri Jul 31, 2015 1:44 pm
Hi All,
I recently upgraded my M2 to the Dual v4 Extruder setup. I'm only using the left nozzle at this time but i noticed a big difference is the print quality using the same Slic3r settings as i was with the older v3b extruder (see picture). I'm fairly certain the bed is properly leveled but i'm not sure what else could be the cause. :shock: Any help would be greatly appreciated.
Print Quality (v3b vs v4 dual)
Print Quality.jpg (102.26 KiB) Viewed 13473 times
Matt_Sharkey
Re: Dual Extruder Upgrade
Post by Matt_Sharkey » Fri Jul 31, 2015 1:51 pm
More details on what you have done for calibration?
adjusted your multiplier?
Z-Offset adjusted?
sckibbons
Post by sckibbons » Fri Jul 31, 2015 2:07 pm
Should i reduce the multiplier or increase it? i think it was set to 1.0 in this photo but I was thinking about changing it to 0.95. The z offset is set to 2mm but should i decrease it to 1mm?
Matt_Sharkey
Post by Matt_Sharkey » Fri Jul 31, 2015 2:10 pm
there's no "doctors orders" on how to set those, its a process that is described well in this calibration thread:
viewtopic.php?f=3&t=1964
sckibbons
Post by sckibbons » Fri Jul 31, 2015 2:26 pm
This is Awesome. Get to pull out the ol' calipers tonight! :D Thanks!!
Matt_Sharkey
Post by Matt_Sharkey » Fri Jul 31, 2015 2:27 pm
yeah pull them out and keep them handy. Dusty calipers are wasted calipers :P
Post by jimc » Fri Jul 31, 2015 2:32 pm
Yes its a totally different hot end setup. Your v3b settings wont work. Everything needs to be retuned for the v4.
sckibbons
Post by sckibbons » Fri Jul 31, 2015 3:47 pm
I was able to find some Slic3r settings for the v3b that someone was able to dial in pretty nicely. Do you know of anything similar for the v4 duals?
https://www.youtube.com/watch?v=m1x7FRm_HSY
Post by jimc » Fri Jul 31, 2015 3:50 pm
The sluc3r user base in the m2 crowd is a bit limited. I have no info for you on it. I only use s3d
PcS
Post by PcS » Fri Jul 31, 2015 5:17 pm
Temps are different between the two aren't they ? Seems like some people had to change printing temperatures slightly. My v4 I run pla at 180 . On the v3b it was 210.
