I am running a file from the SD card and occasionally it will print 1 or 2 layers and then move to front of the table and stop. The table and extruders stay warm but the machine stops printing. I am starting the print with my laptop plugged in with the usb and once it starts I disconnect the usb and use my laptop elsewhere.
Is this file corrupted or what is going on ?
Thanks,
Dan
Running files from the SD card
superiormaker
Re: Running files from the SD card
In addition to the above, I am getting this in the script. I dont know what this means ...... "CRC mismatch detected"
READ: ok T:205.2 /205.0 B:60.9 /60.0 T0:205.2 /205.0 T1:205.0 /205.0 @:46 B@:0
SENT: M105
READ: ok T:205.4 /205.0 B:61.0 /60.0 T0:205.4 /205.0 T1:205.0 /205.0 @:42 B@:0
WARNING: CRC mismatch detected
READ: çw¬Î[&ÿ)ý
ñÇÛo$$±$Y&)+ ÉãK´FFjj"
READ: own command: "-Ѫ"
READ: echo:Unknown command: "ÑÝ¡29ShÞå9¡j8lôÄdô¥Ä"
READ: echo:Unknown command: "g4¬Dg®¸o®»¬f«Ïé_>Ïy\è5BÜq6ÙI(I
IÚK"E2aR¸o¸¸ln¬ÌW
Any help would be appreciated!
Thanks,
Dan
SENT: M105
READ: çw¬Î[&ÿ)ý
IÚK"E2aR¸o¸¸ln¬ÌW
Thanks,
Dan
Could be a corrupted file if it only happens on a specific file. If it happens on more than one file....after a while those little SD cards can get dodgy. Try a new one.
