Need help with settings please
Re: Need help with settings please
If you have a V3-style hotend you very likely rotated the motor mount removing and installing the hotend. This is why you get plastic bunching up on one side while it goes sparse on the other side. Look at it dead-on and ensure it's perfectly 90 degrees from the bed. It's especially telling if you had to redo your Z calibration after changing nozzles...
Good point, thanks will definitely check that one out.
Remember that 0.004 inch = 0.10 mm.jdacal wrote:Bed wasn't off by much, maybe a couple of thousands of an inch
That's half of a 0.20 mm layer and all of a 0.10 mm layer, which will make a huge difference in how well the first few layers work.
ednisley wrote:Remember that 0.004 inch = 0.10 mm.jdacal wrote:Bed wasn't off by much, maybe a couple of thousands of an inch
Thanks Ed. When I wrote that I had already leveled it and was re-printing. It came out much better, still need to check to make sure the extruder is not tilted.
Thanks for all the advise everybody. The nozzle was slightly stilted as well. The biggest part of the problem I think was me not being used to the .5 nozzle. I wasn't expecting so many things to change when I swapped it.
jdacal wrote:Thanks for all the advise everybody. The nozzle was slightly stilted as well. The biggest part of the problem I think was me not being used to the .5 nozzle. I wasn't expecting so many things to change when I swapped it.
