Heating bed to 110 takes a looong time..Normal?
Re: Heating bed to 110 takes a looong time..Normal?
Post by jimc » Tue Feb 16, 2016 4:11 am
the extruder fan is the one that should be on all the time. the bed fan should not. sounds to me like you have them hooked up backwards. in any case its easy to tell. M108 S255 turns on the extruder fan S0 turns it off. as previously mentioned M106 S255 turns on the bed fan S0 turns it off.
scampa123
Post by scampa123 » Tue Feb 16, 2016 4:16 am
jsc wrote:Are you talking about the upper fan? That needs to stay on to cool the extruder, or you will get clogs and possibly a melt down. You can shut it off in the stock M2 firmware using M108, but it needs to be on if the extruder is heated.
Not the one pointing at the extruded, but the one attached to it angled towards the bed. I think it's to cool the plastic as it's printed...
scampa123
Post by scampa123 » Tue Feb 16, 2016 4:26 am
jimc wrote:the extruder fan is the one that should be on all the time. the bed fan should not. sounds to me like you have them hooked up backwards. in any case its easy to tell. M108 S255 turns on the extruder fan S0 turns it off. as previously mentioned M106 S255 turns on the bed fan S0 turns it off.
You were right!! I had the fans reversed. I must have did that when I upgraded to the v4 hotend and the 24v power supply..
Thanks!! :D
