Cylinders aren't round
ksevcik
Re: Cylinders aren't round
Post by ksevcik » Thu Jan 05, 2017 6:34 pm
tk1138 wrote:My glass is (was) sliding around as well. I just noticed it when watching some support material be printed.
I shimmed the front right clip with some silver anti-static material, but I suspect some either some printed shims or cut silicone rubber shims will be a better fix.
I'm pretty sure these adjustable corners also work with little hold down tabs MG sends. If you have a Rev E, you'll want the Rev E version linked in the description. Make sure you print it out of a high temp material like ABS or PC. Maaaybe PETG, but I haven't wanted to risk that yet.
