Getting a "Simplify 3D has stopped working" When slicing.
JohnnyRobot
Post by JohnnyRobot » Sat Jul 26, 2014 8:19 pm
Hey all,
I'm getting a "Simplify 3D has stopped working" windows error message when trying to slice this file.
It must be rotated -90*
https://onedrive.live.com/?cid=FB6F7A8F ... 1D7%212644
Could someone else try it to see if it's the file, or my S3D settings?
-- Hi! No signature here.
Re: Getting a "Simplify 3D has stopped working" When slicing
Post by ednisley » Sat Jul 26, 2014 9:15 pm
Meshlab reports a bunch of self-intersecting faces, plus non-manifold edges and vertices, so perhaps S3D can't cope with the geometry.
Slic3r takes a while to chew through it, but the output looks OK with http://gcode.ws.
I didn't try adding supports, which it will certainly need to be printable!
Post by jimc » Sat Jul 26, 2014 9:18 pm
i just did it and it sliced great in about 10 sec flat. look in your support settings and be sure your pillar resolution isnt set really low. default is 4mm but normal range is from maybe 2-4. when you get real small, under 1mm it can take a really long time and cause possible errors.
Post by jimc » Sat Jul 26, 2014 9:22 pm
ed after your meshlab report i sliced it again which s3d did no problem but i do see evidence of mesh errors in the one hole
JohnnyRobot
Post by JohnnyRobot » Sat Jul 26, 2014 10:35 pm
Strange... Still no luck for me.
I've even tried disabling support material.
JohnnyRobot
Post by JohnnyRobot » Sat Jul 26, 2014 10:49 pm
Hey jimc,
May I please have a copy of the fff file you're using to slice?
I'd like to compare.
Thanks
Post by jimc » Sat Jul 26, 2014 11:07 pm
sure thing. here it is. i was using my .15abs profile for the e3d.
abs15e3d.fff.zip
(2.17 KiB) Downloaded 599 times
JohnnyRobot
Post by JohnnyRobot » Sun Jul 27, 2014 5:35 am
Well,
The fff file you provided did the same thing.
After much messing around with settings, I upgraded to 2.1.1 and it solved the problem!
Post by jimc » Sun Jul 27, 2014 5:37 am
oh yes if you werent on the new version then thats a problem. last update was almost all bug fixes.
