Fan 0 Issue (50mm)
Posted: Tue Jul 29, 2014 2:52 pm
Hi All,
I just got my M2 yesterday and built it all yesterday too. The only problem I am having with anything is the 2 extruder fans. The 50mm and the 40mm. When I plug the 50mm into its respective connection in the harness it does not work (fan 0). However when I switch the 50mm connector to the Fan 1 connector it powers right up and turns.
This proves that the 50mm is not DOA.
I also know that when the plugs are suppose to be with the fans the 40mm works perfectly so that is also not DOA.
When switching the fan 0 connector to the 40mm the fan will not work, but when switching fan 1 to the 50mm it will work.
This leads me to think that the fan 0 connector is not properly working by deduction.
