fan not turning on
dbkarmann
fan not turning on
Post by dbkarmann » Sat Aug 02, 2014 9:17 pm
so i changed profiles from abs to pet + and my extruder fan doesnt turn on. I changed profiles back to abs and now everytime i start a print i manually have to turn the extruder fan on. I have never had to do this before. any suggestions on how to fix this problem?
thank you
david
Re: fan not turning on
Post by jimc » Sun Aug 03, 2014 12:55 am
Check your starting gcode. Check if there is an M108 command. It should have a value of 255 not 155. 155 is for the older 19v machines.
dbkarmann
Post by dbkarmann » Sun Aug 03, 2014 1:23 am
just checked it says M108 S255
Post by jimc » Sun Aug 03, 2014 1:35 am
Ok thats right. So when you say your turning the fan on manually how are you doing it? This is tue extruder fannnot the bed fan correct?
dbkarmann
Post by dbkarmann » Sun Aug 03, 2014 1:48 am
yeah its the extruder fan. i use the viki lcd controller to go in after the print starts to turn it on. i have never had to do this before. the only thing i did was load the file for pet+ and then changed it back when i failed at pet+ lol
Post by jimc » Sun Aug 03, 2014 2:37 am
I cant think of anything at the moment. M108 controls the fan so if that is set to 255 then the fan should be on
dbkarmann
Post by dbkarmann » Sun Aug 03, 2014 3:38 am
yeah im confused
Post by jimc » Sun Aug 03, 2014 4:18 am
Go into your start gcode and just before the m108 line put an M400. No value needed with that just m400. That makes the printer wait until it completes all previous commands before it continues.
dbkarmann
Post by dbkarmann » Sun Aug 03, 2014 5:13 am
ok ill try that
thank you
dbkarmann
Post by dbkarmann » Mon Aug 04, 2014 10:03 pm
the fan comes on while heating but turns off when the print starts
