I am a new user of the M2 and I have noticed on some of my thicker plastic prints that my front two corners are curling up a bit while printing.
The print is a 2 inch square that is 1/4" thick.
Since it was the front two corners I figured it may be caused by the fan blowing on those corners more than the back corners, so I tried turning the fan off and it seems to be helping ( But it could be also that I gave the Glass a real good cleaning )
I am using the PLA
Extruder Temp: 217
Bed Temp: 70
Platform is Glass with no tape or other things on it.
So my question would be is it ok to run with the fan turned OFF on the whole printing process?
Thanks for any help on this....
Kent
Fan speed Question
Re: Fan speed Question
You want to have the fan running for all but the first layer on PLA, to prevent heat warping. To help with corner adhesion, you can try a brim, but my suggestion is to use glue stick, or one of the other methods in the M2 tips thread. Clean glass is a hit or miss affair, and depends on how meticulously you clean it.
You might also try a bed temperature of 60. Too warm and the bottom layer goes soft and can pull up.
I had the same problem when I started. The Elmer's purple glue stick eliminated for me.
EDIT: Also using 60 degree bed as jsc suggests.
