Hello everyone,
I have my M2 for a year and now for the first time I had this problem.
After half hour of work, my print job beginning crashed every 5-10 seconds with pause of 1-2 seconds then more and more frequently until to stop permanently after 5 minutes like was a lag in communication. I restarted both printer and PC restarts printing but after an hour of work I had the same problem. The pc running the printer manager program only with no other active programs.
Someone has already happened?
Who can help me? please
Thanks to all
Cris
slow step by step print
Re: slow step by step print
Does this happen if you are printing from the SD card?
Does this happen at the same point in the print? Is there any defining feature at that point in the print, if so?
If you are printing via USB, it would be VERY interesting to look at system resources (memory, CPU) to see if there's a memory leak (or worse). And, if printing via USB, could you try preparing print to SD card (plugged into your PC is fastest) --- use an 8x3 filename in uppercase to avoid issues with Long Filename support, e.g.: "OBJECT.G". Then put the SD card in the M2 and start the print from there.
Note: having the PC go to sleep or power down, or doing a clean disconnect of USB, during an SD card print can cause the M2 (depending on recent-ness of firmware) to reset, aborting the print. Once you start the SD card print, yank the USB cable between the PC and M2 --- the M2 will keep on printing. Should finish fine from there.
If that works OK and printing over USB from the PC dies after a while, I'd suspect a driver issue or something else that is consuming, and not releasing, PC resources...
Thank you insta, I had no try with SD card because I had remove the lcd panel for a problem.insta wrote:Does this happen if you are printing from the SD card?
I have not figured out what's wrong, the piece is very simple. The printer has stopped the first time after half hour of work and the second after 1 hour, then at two different points and I can't find a similarity between the two.insta wrote:Does this happen at the same point in the print? Is there any defining feature at that point in the print, if so?
I print via USB but I had check al the PC resource (CPU, RAM, disk, ecc) and they seem unoccupied.Dale Reed wrote:If you are printing via USB, it would be VERY interesting to look at system resources (memory, CPU) to see if there's a memory leak (or worse).
Tonight I try to connect the LCD and print from SD card and then I keep you inform.Dale Reed wrote:And, if printing via USB, could you try preparing print to SD card (plugged into your PC is fastest) --- use an 8x3 filename in uppercase to avoid issues with Long Filename support, e.g.: "OBJECT.G". Then put the SD card in the M2 and start the print from there.
Thank you very much
Gre
As insta and Dale said, first thing to check if it's the USB connection is an SD print. How does it fail, though? Does the print just pause permanently, or do the motors release and the bed drop? If the later, that can happen when pressure is exerted against the bed. I haven't seen it happen during a print, but it has happened when I tried to run a print with one already on the bed which contacted the gantry. I've also seen it happen to a friend's M2 during a startup sequence. The issue in his case was that he had never lubricated it, ever.
That last one sounds like too much current draw, resulting in a sag of power supply voltage, resulting in an LVD (low voltage detect) interrupt/reset of the micro. I'd start checking for loose connections, everywhere, but especially at the 6-pin power connector at the back of the RAMBo.
