Broken Motor shaft on extruder
Posted: Mon Jan 19, 2015 1:06 am
I was in the middle of printing a part today and my extruder motor quit on me..
I took the motor apart and discovered that the shaft on the motor snapped off the motor. ( See photo below )
Also in the process it looks like it may have blown something on my main board on the machine because when I tried to do a manual jog on that motor the main shaft doesn't move. I tried moving it to my X-axis just for testing and the motor does turn on when I jog it from there.
So that is why I am coming to the conclusion that when the motor originally jammed up that it may have caused something on the main board to burn out.
Questions:
Is this common for the extruder motors to fail?
Are there any higher quality motors out there as replacements?
Am I correct that I probably burn something out on the main board since that circuit isn't working anymore?
is there something else that I can check?
If the board is bad I'm hoping it's not going to set me back $$$ to bad...
I'm kind of in a bind now since Makergear is out of stock on these motors.
Thanks,
Kent
Questions:
Thanks,
Kent
