Bed stops heating
Artenen
Bed stops heating
Post by Artenen » Tue Mar 24, 2015 1:52 pm
Suddenly for no reason my bed will no longer heat. I checked for loose wires, reset the program and then printer and nothing...
Any suggestions?
Re: Bed stops heating
Post by jimc » Tue Mar 24, 2015 5:53 pm
check the fuse on the rambo? check the red plug connecting the hbp. make sure you dont see anything melted. the 12/19v machines could melt the connection in the plug where the power supply connects to the rambo. check that its not melted or black connections. if everything there is ok then i say you have a break in a wire going from the hbp to the rambo. flexing back and forth over time can cause breaks inside the wire itself.
sprior
Post by sprior » Tue Mar 24, 2015 7:06 pm
Check the bed thermistor, if the RAMBo doesn't see a valid temp it will refuse to heat. Happened to me once.
Rara
Post by Rara » Tue Mar 24, 2015 7:13 pm
Every time I ran in to this it was the PSU to Rambo connection melting down. On round 3 I said screw it and soldered the 12v wires directly to the Rambo and used a terminal block to make it overbuilt yet removable. No issues since.
2012 M2 V4-PTFE
Artenen
Post by Artenen » Wed Mar 25, 2015 3:04 pm
It was a split wire, missed it the first go round as the heat shielding was still holding.
Bluesoulx12
Post by Bluesoulx12 » Sun Apr 05, 2015 9:56 pm
Where was the split wire? I am having the same issues as my M2 will record all the values properly, but not heat up at all.
Artenen
Post by Artenen » Mon Apr 27, 2015 8:30 pm
It failed right by the deans connector (the red connector right off the bed). I ended up just hard wiring it as every time I'd fix it, it would fail someplace else down the line because of the movement.
Bluesoulx12
Post by Bluesoulx12 » Wed Apr 29, 2015 12:59 am
Yeah mine failed after the female and male connection because of the movement. Makergear replaced it under warranty very quickly. Tips to their customer service as always!
