filament
filament
Ok I am having trouble with filament. Can anyone recommend a good filament that works great with the M2. The stuff I purchased does not adhere to itself well PLY and ABS. I use multiple colors so I need a good source.
Re: filament
Take your pick ...
eSUN has treated us well in the past, we go through a local distributor in the US -- intservo.com. The same plastic is also sold under MicroCenter's house brand "Inland".
I use Ultimachine plastics too, especially their PLA if I can get it on sale.
What plastic were you using, and what settings? I've almost never had a problem with plastic not adhering to itself, usually its the bed it has an issue with.
Re: filament
For PLA and ABS, can't go wrong with the stuff MakerGear sells on its web site.
What temperatures are you running with these? If you have experience with other printers, you may need to dial up 10 to 20 degrees. The temperature sensor on the M2 V3b and V4 hot ends is near the heater, but there's a temperature gradient from there to the tip of the nozzle. If you're used to running PLA at 190 to 195, try about 210 on the M2. If you're trying to run ABS at 220, try more like 240. Full fan on PLA, NO fan on ABS, and with ABS you may need an enclosure.
eSun / intservo PETg and MadeSolid PET+ (at least the clear ones) have great adhesion layer-to-layer if you run hot enough (245-ish) with way less curl/shrinkage than ABS. It'll take a bit for you to work out the settings to control the drool and stringing with PET, but you'll find it time well spent. A couple folks here have tried-and-true profiles for PET that then can share. (I'm not near my printing PC to grab one for you right now.)
Re: filament
I can second Inland, perfect filament and the best price I have ever seen.insta wrote:Take your pick ...
Re: filament
i've had good luck with (and in no partiular order)
folger tech
jet
makergear
makerbot
esun
folger tech
jet
makergear
makerbot
esun
Re: filament
I have not found any that I can't run with the right settings. I wonder it is indeed the filament ? Even cheap Chinese stuff gives me great results. In fact the best pla and the one I use all the time is 12 dollars a roll next day delivery off of ebay. Lol
Re: filament
I do find that each maker has diffrent optimal settings. i typicly write the temp and filiment size right on the spool once i figure it out again.
Re: filament
in general over the past 2 years i have noticed filament getting better and better where even the cheap import stuff has been good. when i started 2 1/2 years ago that wasnt the case. there was a ton of crap out there. you really had to watch what you buy.
