EXTRUDE_MINTEMP and M302 questions
Posted: Thu Aug 20, 2015 5:06 pm
Ok, I understand the minimum temperature at which the extruder motor will operate is controlled in the firmware using the line- define #EXTRUDE_MINTEMP 170. If you are a firmware modding kind of person, then you can change this to whatever number your like and reload the firmware.
If you want to do it the easy way and have S3D, you can go to the Machine Control Panel and under the Communications tab, type M302 and press SEND to disable the mintemp setting. This only temporarily disables the mintemp setting. Once you use Disconnect/Connect or power down and restart, the M2 will reset to its default mintemp setting
Great, but what if I am REEEEALLY lazy and just want this code to be inserted automatically in an fff file using the Scripts -> Starting Scripts and Ending Scripts function? That way I don't even have to think about this stuff and can just download some smartypants guys FFF settings.
I found a couple of posts mentioning you could send M302 SXXX (where XXX is the desired mintemp). This would allow you to set AND reset the mintemp for a filament using the Scripts Tab. For Example: Under Starting Scripts add in M302 S80 and under Ending Scripts add in M302 S170
It makes perfect sense!
Except it doesn't work for me.
Well, sorta it does. The M302 command definitely disables the mintemp setting altogether. The other half of the setting , the SXXX code or "sS80" or "S170" does not work to reset or re-enable the mintemp setting.
Why might that be? Can someone else try this to confim it or let me know how I have messed up? Or just show me an even lazier way to make it work?
