Spare Hardware
jdacal
Spare Hardware
Post by jdacal » Fri Sep 04, 2015 1:35 am
I need to get about 4 of the replacement bolts for the bolt and nut that holds the bearing on the drive. Anyone have a source and part number for that. Also the filament adjustment bolt. Don't see those listed on the parts breakdown.
jdacal
Re: Spare Hardware
Post by jimc » Fri Sep 04, 2015 3:18 am
yeah the shoulder bolt. you have 2 options, makergear or mcmaster. mcmaster does have them. i found them before but honestly its just easier to email karen. the tension screw is a 4x16mm. also available from mcmaster and makergear.
here you go. i had to look up my order history back in 2013. the shoulder bolt is 90278A372. if you need the bearing, it is 6153K15.
jdacal
Re: Spare Hardware
Post by jdacal » Fri Sep 04, 2015 3:55 am
Thanks Jim. I had looked on there but the one's that kept coming up for the bearing bolt were 12mm and 16mm, didn't show 14mm shoulder. Came right up with your part number, thanks.
jdacal
