I think my extruder stepper driver might have died..
Posted: Sat Sep 26, 2015 2:45 pm
Hey all!
So, I have an issue with my M2.
Symptoms:
Extruder not extruding or retracting. In fact, it is not making any movements at all.
I have checked that the cable is intact, I checked the fuses on the RAMBo and that all cables are firmly attached.
What led up to this?
I had just gone through another levelling exercise and was a bit off in the Z-level. some 0.05 or so.
Instead of re-slicing, I found a gcode for setting the z-index in the firmware, which I thought could be a good start:
M212 Z<offset> was the command.
It was followed with a few different values, then M500 and M501 to store them.
Turns out it had little or no effect...
I DON'T think this could have caused the error in any way. I haven't looked at the code much yet, but it did not return anything from the printer.
It started with the VIKI2 display starting up, first screen seen, then into the menu and then totally white.
In fact, it looks like you were constantly pressing the button.
I have replaced the VIKI2 with my old VIKI and uploaded firmware again. Old VIKI doesn't seem to give any errors, but extruder is still not extruding.
Any suggestions to what I can measure to see if my driver is intact?
Any suggestions to how I can change my code to use the E1 extruder instead of E0, or does it need to sit an extruder in E0 to get E1 to work?
Just thought I could try and take the stepper motor out of the equation.
thanks,
Micke
Symptoms:
thanks,
Micke
