Heat Creep/Soak?
Mark the Greater
Heat Creep/Soak?
Post by Mark the Greater » Wed Oct 07, 2015 11:47 pm
'ello.
I have a V3B hotend and it is acting up. What part of the hotend should be the hottest? At 260C: my nozzle is warm, my heater block is warm, and my GrooveMount is about to catch fire. As in over 300F.
Is this normal or indicative of a problem?
Love Always,
MtG
Re: Heat Creep/Soak?
Post by Jules » Thu Oct 08, 2015 12:19 am
The nozzle should be the hottest. Turn the machine off. Go look at the PM reply i sent you and take a look at the bottom drawing here - had a bit of trouble finding it, but I knew it was out there:
http://makergear.wikidot.com/m2-extruder
You'll need to cut the filament above the hotend before you can get the drive off.
Mark the Greater
Post by Mark the Greater » Thu Oct 08, 2015 12:20 am
...or I could crack the drive housing prying it out...
Love Always,
MtG
Mark the Greater
Post by Mark the Greater » Thu Oct 08, 2015 12:47 am
Furthermore, should I be seeing hotspots on my heating block? As in most of it doesn't get about room temp.
Love Always,
MtG
Post by Jules » Thu Oct 08, 2015 12:50 am
Mark the Greater wrote:...or I could crack the drive housing prying it out...
Oh no! (Hope you're kidding.) :shock:
Mark the Greater
Post by Mark the Greater » Thu Oct 08, 2015 12:52 am
Heh. It's all good. I mean, yeah I cracked it but it isn't bad enough to effect printing. Once I get this sorted I'll just make another.
Love Always,
MtG
Mark the Greater
Post by Mark the Greater » Thu Oct 08, 2015 2:05 pm
Screw the whole thing. I'm just going to upgrade to the V4.
Love Always,
MtG
Post by Jules » Thu Oct 08, 2015 2:37 pm
It's a good upgrade to make - much easier to get the V4 hotend out of there and reset the Z-stop with that one. :)
