So where's the all-metal motor mounts?
swbluto
Post by swbluto » Sat Nov 14, 2015 3:59 pm
I'm wondering, is this an official endeavour by Makergear or is this some independent hobbyist kind of thing? Essentially, If, when and where can I expect to buy one? [Independent hobbyists are iffy commercial sources.]
3dPrintingMD
Re: So where's the all-metal motor mounts?
Post by 3dPrintingMD » Sat Nov 14, 2015 7:28 pm
A user posted a video of his brand new M2. It had an all metal motor mount. MG commented that it will be available soon. I want one as well.
swbluto
Post by swbluto » Sun Nov 15, 2015 12:27 am
I would absolutely love if I could make my M2 do everything my other printers can. It's quite sad to see that it can't do 80% of my highly detailed work, currently, even though I know it could do it if just had the right parts.
Anyway, reassuring that MG states it will be out soon. That means it's official, hoorah!
Vandal968
Post by Vandal968 » Sun Nov 15, 2015 12:49 am
Is this what you're talking about?
http://www.ebay.com/itm/ALL-METAL-3D-PR ... 1146824305
c
Post by sthone » Sun Nov 15, 2015 2:16 am
No that's not what they are talking about but take it from me stay away from that ebay extruder it's not worth it.
Farr0wn3d
Post by Farr0wn3d » Sun Nov 15, 2015 4:45 am
Can someone post the video of this? I'd like to see this beauty
Post by jimc » Sun Nov 15, 2015 5:16 am
im wondering what you think your going to gain by a metal motor mount? no reason in the world why you cant get highly detailed prints out of your m2. the stock mount is very rigid. if you want it more rigid then print a replacement with 95-100% infill. it will be like a rock.
Farr0wn3d
Post by Farr0wn3d » Sun Nov 15, 2015 5:19 am
I had actually thought he was referring to a metal extruder setup, but either way my original motor mount that came with the m2 has cracked so I need a replacement either way, and who doesnt like the look of machined metal components over printed plastic ones?
Post by jimc » Sun Nov 15, 2015 5:22 am
Farr0wn3d wrote:I had actually thought he was referring to a metal extruder setup, but either way my original motor mount that came with the m2 has cracked so I need a replacement either way, and who doesnt like the look of machined metal components over printed plastic ones?
that was for the op. in any case, sure the metal component are nice and very strong but you arent going to gain print quality with one.
swbluto
Post by swbluto » Sun Nov 15, 2015 5:56 am
So the issue with the quality of thin columns isn't with the rigidity of the motor mount, but rather the retraction 'leakiness'?
I wonder why the M2's extruder leaks but my replicator's extruder largely doesn't (Doesn't require negative restart, whereas negative restart helps the M2 but it's not a cure-all. Curing the hairiest of hairs in some prints with a high restart value of -.6mm introduces noticeable gaps in the wall, weakening it.)? Does it have something to do with the extruder motor? The filament hot chamber design?
