Getting PETG to stick
Farr0wn3d
Post by Farr0wn3d » Sun Nov 15, 2015 7:54 am
I've tried printing with the bed at 87 and 60, with PVA/water and with hairspray and no matter what, I get parts lifting off the bed at the edges, not just on large parts either.
I'm using garnier fructis hairspray, "ultra strong" hold. but maybe theres a better choice? let me know!
Vandal968
Re: Getting PETG to stick
Post by Vandal968 » Sun Nov 15, 2015 9:10 am
I've had good luck with both elmers glue stick and aquanet. Although, after reading here about the joys of PEI, I switched a few weeks ago and it's fantastic, I don't plan on ever going back to those messier solutions.
cheers,
c
PcS
Post by PcS » Sun Nov 15, 2015 1:12 pm
I you are having those problems with petg and hairspray then I highly recommend releveling your bed and adjusting your Z gap. When you get everything right prints don't come off the bed very easily even after it has cooled.
Post by jimc » Sun Nov 15, 2015 2:09 pm
Yeah i agree. Your using the right hairspray so if your bed gap and first layer go down right then petg will stick fantastic to that spray with no issue.
Farr0wn3d
Post by Farr0wn3d » Sun Nov 15, 2015 4:56 pm
Bed gap, bed level, and extrusion calibration as most definitely NOT the problem lol, I level my bed with a dial indicator gauge with excellent repeatability, I do the 2mm calibration print for both extrusion and z height every time I change my hot end.
I put my first layer down at 97%, sometimes 95%, maybe I need to lay it down thinner?
Vandal, where are you getting your PEI from?
Vandal968
Post by Vandal968 » Sun Nov 15, 2015 5:36 pm
This is the PEI I bought:
http://www.amazon.com/gp/product/B0013H ... ge_o08_s01
and this tape:
http://www.amazon.com/gp/product/B007Y7 ... ge_o08_s00
If ordering again, I'd probably go for wider tape, maybe 2". The edges are a bit tricky to get laying flat. Twice as wide, half as many edges to worry about.
cheers,
c
Farr0wn3d
Post by Farr0wn3d » Sun Nov 15, 2015 7:11 pm
so you just cut the PEI to the size of the glass and then stretch it and tape it around the to back?
Farr0wn3d
could you post photos of your setup?
Post by Jules » Sun Nov 15, 2015 7:17 pm
Farr0wn3d wrote:so you just cut the PEI to the size of the glass and then stretch it and tape it around the to back?
PEI doesn't stretch, it's a solid thick sheet of plastic that you attach to the glass using the tape, and then trim away the excess plastic. It's very hard to cut without a plastic cutter. (Available at Amazon.)
There is a thread on it, with the best methods for applying it here:
viewtopic.php?f=10&t=2296
Farr0wn3d
Post by Farr0wn3d » Sun Nov 15, 2015 7:23 pm
what filaments stick to PEI?
