Page 1 of 3
Getting PETG to stick
Posted: Sun Nov 15, 2015 7:54 am
by Farr0wn3d
I've tried printing with the bed at 87 and 60, with PVA/water and with hairspray and no matter what, I get parts lifting off the bed at the edges, not just on large parts either.
I'm using garnier fructis hairspray, "ultra strong" hold. but maybe theres a better choice? let me know!
Re: Getting PETG to stick
Posted: Sun Nov 15, 2015 9:10 am
by Vandal968
I've had good luck with both elmers glue stick and aquanet. Although, after reading here about the joys of PEI, I switched a few weeks ago and it's fantastic, I don't plan on ever going back to those messier solutions.
cheers,
c
Posted: Sun Nov 15, 2015 1:12 pm
by PcS
I you are having those problems with petg and hairspray then I highly recommend releveling your bed and adjusting your Z gap. When you get everything right prints don't come off the bed very easily even after it has cooled.
Posted: Sun Nov 15, 2015 2:09 pm
Yeah i agree. Your using the right hairspray so if your bed gap and first layer go down right then petg will stick fantastic to that spray with no issue.
Posted: Sun Nov 15, 2015 4:56 pm
by Farr0wn3d
Bed gap, bed level, and extrusion calibration as most definitely NOT the problem lol, I level my bed with a dial indicator gauge with excellent repeatability, I do the 2mm calibration print for both extrusion and z height every time I change my hot end.
I put my first layer down at 97%, sometimes 95%, maybe I need to lay it down thinner?
Vandal, where are you getting your PEI from?
Posted: Sun Nov 15, 2015 5:36 pm
by Vandal968
This is the PEI I bought:
http://www.amazon.com/gp/product/B0013H ... ge_o08_s01
and this tape:
http://www.amazon.com/gp/product/B007Y7 ... ge_o08_s00
If ordering again, I'd probably go for wider tape, maybe 2". The edges are a bit tricky to get laying flat. Twice as wide, half as many edges to worry about.
cheers,
c
Posted: Sun Nov 15, 2015 7:11 pm
by Farr0wn3d
so you just cut the PEI to the size of the glass and then stretch it and tape it around the to back?
by Farr0wn3d
could you post photos of your setup?
Posted: Sun Nov 15, 2015 7:17 pm
Farr0wn3d wrote:so you just cut the PEI to the size of the glass and then stretch it and tape it around the to back?
PEI doesn't stretch, it's a solid thick sheet of plastic that you attach to the glass using the tape, and then trim away the excess plastic. It's very hard to cut without a plastic cutter. (Available at Amazon.)
There is a thread on it, with the best methods for applying it here:
viewtopic.php?f=10&t=2296
Posted: Sun Nov 15, 2015 7:23 pm
by Farr0wn3d
what filaments stick to PEI?
