Layer height-dependent settings? Or something else?
Posted: Mon Nov 30, 2015 3:47 pm
Hi everyone,
I have had a lot of success printing PLA parts with a 0.2 mm layer height. However for some of the parts I need to print, the 0.2 mm resolution is unnecessarily high so I've been trying a few parts at 0.3 mm layer height to save print time. At first, I thought that I could get nice prints by simply changing the layer height setting and leaving everything else the same. However, I've now realized that almost definitely isn't the case. I printed one part that was roughly 1" (X-dir) x 9" (Y-dir) x 6" (Z-dir) at 0.3 mm layer height with all other settings the same as my 0.2 mm layer height settings, and it turned out great. But now I'm thinking that was probably a fluke.
My problems began when I tried to print the part pictured below. The beginning of the print looked pretty normal but when I came back to check the print about halfway through, I noticed that all of the surfaces parallel to the Y-axis (the shorter faces the way I placed the print on the bed) had weird vertical ridges (first picture). The surfaces parallel to the X-axis (the longer faces) were normal. Also, the infill seemed to be sagging below the level of the perimeters. In the spirit of discovery I decided to let the print complete. The pictures below are of the completed print. It might be hard to tell from the pictures, but the same problems persisted - ridges in all surfaces parallel to Y-axis and sagging infill. The top surface is slightly recessed and a bit porous-looking as a result.
My next step was to run a test/calibration print with the same settings. I got the same result (image below, right - I stopped it mid-print). Then I ran the same test print with my 0.2 mm layer height settings and got a perfect print (image below, left). Finally I ran my part again with the 0.2 mm layer height settings and got a perfect print.
I feel like these observations indicate that the cause of my problem is something in my process settings for the 0.3 mm layer height. I am using S3D. Again, the settings I tried to use are exactly the same as the settings I have used to produce many successful prints at 0.2 mm layer height, except for the following:
- "Primary Layer Height" is 0.3 mm instead of 0.2 mm.
- "First Layer Height" is 60% instead of 90%, so that the actual layer height is the same (I am currently using this instead of the g-code offset to control the first layer height. It might not be the best way but I don't think that's my problem here...right?)
- All other settings exactly the same. Nozzle temp is 215 C. I have the V4 extruder.
So I guess my question is, what other settings should be changing when I change the layer height from 0.2 mm to 0.3 mm? Is my problem under-extrusion? Do I need to turn up the extrusion multiplier or width when I increase the layer height?
Thanks for any feedback/assistance.
