Page 1 of 3
Snapped Hot End
Posted: Sun Dec 06, 2015 11:50 pm
by Mach
I recently picked up a new M2 and ordered a stainless nozzle for printing glow and brassfill. In the process of taking apart my hotend, I snapped it at the heatbreak. Lesson learned on how delicate it is. I've order 2 more from Makergear.
Is the broken one now junk? Is the assembly 1 piece or is the heat break threaded into the main part of the hotend?
Re: Snapped Hot End
Posted: Mon Dec 07, 2015 12:53 am
You can screw the nozzle off and re-use the thermistor if you need it down the road. Breakdown instructions for the V4 are here:
viewtopic.php?f=3&t=2942
Re: Snapped Hot End
Posted: Mon Dec 07, 2015 1:12 am
by MagicEngineer
If you look through the forum you will find that quite a few of us have done the same thing. It's an expensive lesson, but one you usually only have to learn once.
Re: Snapped Hot End
Posted: Mon Dec 07, 2015 6:16 am
by Mach
Thank you both for the input. I'll hang onto the broken one then.
Re: Snapped Hot End
Posted: Mon Dec 07, 2015 5:31 pm
by sthone
Mach wrote:I recently picked up a new M2 and ordered a stainless nozzle for printing glow and brassfill. In the process of taking apart my hotend, I snapped it at the heatbreak. Lesson learned on how delicate it is. I've order 2 more from Makergear.
Let me guess you tried to change the nozzle with it mounted in the press right?
Looking at the broken one I have
it looks like they are press fit together.
I was looking at ordering some materials to try and fix the one I have... does anyone know what type of PTFE these are lined with? I looked on Mcmaster and it looks like there is a few different kinds of PTFE choose from.
Re: Snapped Hot End
Posted: Mon Dec 07, 2015 5:43 pm
by SouthSideofdaSky
sthone wrote:does anyone know what type of PTFE these are lined with? I looked on Mcmaster and it looks like there is a few different kinds of PTFE choose from.
Rick posted this back in February and I bookmarked the post...don't know if the design has been tweaked since then or not though...
viewtopic.php?f=13&t=1606&p=8646#p8646
Re: Snapped Hot End
Posted: Mon Dec 07, 2015 6:33 pm
by Mach
Oh yeah, just like I knew what I was doing. Rookie mistake compounded by Murphy's law - I was able to find the instructions for changing the nozzle after I broke it. I should have searched harder.
As a suggestion, would it be possible to ship nozzle instructions or a link to the instructions with the replacement nozzles. I've already paid for my knowledge but it may benefit future newbie or the absent minded. On a plus side, the MG team has already shipped my replacement.
I thought the heatbreak was made of metal but I did not look at it too closely. I can take some macro shots tonight. I'd rather fix it for a backup if possible.
Edit: No its not just PTFE. Scott at MG support replied that the replacement barrels are for sale but they're a bear to replace. I'm going to give it a shot.
Re: Snapped Hot End
Posted: Mon Dec 07, 2015 7:18 pm
by sthone
Thanks.. I was going to order a rod and see if it could be machined but that narrows it down for me. Going to see if I can get the bit and pieces out of the old block first.
Re: Snapped Hot End
Posted: Tue Dec 08, 2015 1:37 am
Just for giggles, I took apart the hotend I set fire to. It was pretty easy, I removed the heater cartridge and thermistor, then slipped a deepwell socket over the upper barrel against the block, then squished it with a C-clamp. Almost immediately, and with a loud pop, the barrel jumped out. It didn't take much squeezin' to get it to stick back in the block either, although I'm sure there's an official way to do it.
Re: Snapped Hot End
Posted: Tue Dec 08, 2015 2:00 am
by sthone
Thanks for the socket idea insta, I used a small arbor press and socket and it popped right out. This is going to be easier to fix than I though, just need to drop MG a email and order a new barrel.
I wonder why the barrel is cut like that though, it seems like that's a unnecessary weak spot in the design.
