.25 WITH HATCHBOX WOOD
sporter16
Post by sporter16 » Mon Feb 22, 2016 7:55 pm
I have succesSfullY printed Hatchbox Wood on a .35 nozzle a number of times, but as soon as I switched to the .25 nozzle....it clogged. (upped the temp to 230 out the gate) I am relatively new to the 3d printing world, and I was told that the nozzle size might be too small for the wood filament, however I have seen a user on here print successfully with this combo.
ANY SUGGESTIONS?
NOZZLE-.25
WIDTH-.30
LAYER-.2000
TEMP-230
willnewton
Re: .25 WITH HATCHBOX WOOD
Post by willnewton » Tue Feb 23, 2016 3:25 pm
You probably should not be using that small of a nozzle or that high of a temperature. The wood particles are known for clogging tiny nozzles. The high temp will also cause the filament to burn and clog if it sits in the nozzle for too long. Also, printing with your temps at 20-30° above the usual temps is a sure sign that you have a clog starting.
1. Go back to .35mm. Small nozzles and tiny layer heights rarely mean better prints.
2. Get back to 200-205°
3. Unclog your nozzle.
viewtopic.php?f=11&t=3038
sporter16
Post by sporter16 » Tue Feb 23, 2016 3:46 pm
THANK YOU, I WILL GIVE IT A GO!
Post by sthone » Tue Feb 23, 2016 4:47 pm
That was probably me... :D I did print the Hatchbox with a .25 nozzle but I also did have a clog or two doing while doing it but I also expected it to happen.
I'll have to double check by I'm pretty sure I printed at...
Temp 205°
.10-.15 layer heights (I was experimenting)
Nozzle - .25
.25 width (because I was printing tiny stuff)
Not sure if it makes a difference but I was also printing with Concentric infill so it had more of a wood like pattern on the external layers.
Honestly though like Will said unless your printing tiny things and need high detail I would stick to a .30 or larger nozzle.
sporter16
Post by sporter16 » Tue Feb 23, 2016 5:49 pm
It was most certainly you and thanks for the reply. I will give it a shot, when I am brave enough to put that .25 nozzle back on.
