I have a MakerGear M2 (2013) model and the heater bed no longer heats up.
I purchased a new heater bed but that was not the problem as the new one does not heat up either.
Has anyone else experienced this problem? might it be the cables have a break internally due to the many hours of printing? Might it be the board controller?
Any help would be greatly appreciated.
HEATER BED DOES NOT HEAT UP
Re: HEATER BED DOES NOT HEAT UP
Did you melt the connector going into the RAMBo? Your machine is at the age that you should do the full 24v upgrade from MakerGear -- this includes a new everything and will definitely get your heatbed running again if it's not a software issue.
Short answer: yes.COBRAJET wrote:might it be the cables have a break internally
Longer answer: Check the platform heater wire joints / connectors...
- Near the connector at the platform
- At the connector inside electronics box
- At the power connector from the +12 V brick
It could be a failed MOSFET on the Rambo board, but that's the least likely situation.
Good hunting...
