Does anybody know where to get the female Molex connector going from board to Extruder Stepper Motor?
Thank you,
Naz
Extruder Stepper Motor Molex Connector
Re: Extruder Stepper Motor Molex Connector
You can get all the connectors you need from Digi-Key (http://www.digikey.com).nazekaosman wrote:Does anybody know where to get the female Molex connector going from board to Extruder Stepper Motor?
On the stepper motor side, the connector is similar to a Molex but the type used is made by JST:
JST-PH Series, specifically the JST-PH6 (JST style, PH Series, 6 positions), Digikey part# 455-1162-ND.
On the board side, the connector is a Molex, Digikey part# WM5364-ND. I had an old RAMBo when I traded it in for a Smoothie, but I think they still use a plain 4-pin socked that does not have a keyed header, specifically so that the plug can be put in either way.
