Need Help!! Metal bracket (on Dual) for hotends
Posted: Fri May 06, 2016 5:05 pm
I had a clog today, loosened my hotened to remove from bracket and when I went to push it back into place I must have put it into another hole in the bracket....
When I tightened down the set screw I couldn't understand why it wasn't holding the hotend in place....
When I finally realized I was in the incorrect hole and went to put the hotend in the correct hold for the tension screw I had inadvertently must have tightened the set screw to the point that the hole for the hotend closed a bit...
Not I am unable to get the hotend back into the hole in the bracket...
I've tried to gently use a flat screwdriver to open the hole bit (both on the edge where the bracket comes together with the set screw and in the how itself, but it's not working out well...
Anyone have any suggestions on how to widen the hole a bit to get the hotend back in?....
Thanks!!
Thanks!!
